Hi all
I just got back from my trip to LA. I collected the 48 IDA Webers and Cobra manifold that I won on the E-Bay auction site. The seller who lives in LA also had an alloy Cobra oil pan so I purchased that as well. After some discussion with the seller he mentioned that Hawaii Racing was just down the road and was also worth a visit for engine parts, so off I went.
I found Hawaii Racing at 21 Easy Street, Simi Valley CA 93063. Web site http://www.hawaiiracing.com/ Tel (805)583-8880
When I entered their establishment I felt close to heaven, on my left as I went through the door there was a Boss 429 overhead cam Ford,
lots of other newly prepped Ford and Chevy custom race engines.
Then I walked past hundreds of custom race parts alloy cylinder heads, stroker crank kits, alloy inlet manifolds of all descriptions and much more until getting to counter. I said that I was in LA looking to buy a few engine parts and would like some advice as to what they had to offer for a Track GT40.
I was invited into the back (THE TOY ROOM.) sat by a very shiny Ford small block was Joseph Souza the owner of the shop. After a chat with Joe I realised that this was the guy that had been the spanner man on the Hawaiian Funny car that was campaigned from the sixties and was featured in many of my old HOT ROD magazines.
Well, I ended up ordering a complete engine. The spec is as follows
Ford Racing 4 bolt main block bored +30 using torque plates = 308 cu inches.
lightweight H beam 5.4" LONG Rods
Lightweight Custom forged pistons with higher wrist pin position for the long rods.
Standard Stroke lightweight crank internally balanced, using heavy metal.
Custom grind solid roller cam
Victor Junior alloy heads
Alloy Roller rockers.
Belt drive for the cam with Venire adjustment.
Block mounted electric water pump
I left the cobra inlet manifold with Jo so that it can be matched and flowed to the heads. The alloy sump is to be modified to suite the windage tray and have two trap doors installed to control oil surge.
We decided on the long rod approach instead of stroking to improve engine efficiency reducing piston side loading, and increase compression to 12:1 because of the better combustion afforded to us by a long rod engine. I also believe this approach will make the engine very responsive especially with a Tilton lightweight clutch and flywheel set up.
The rod stroke ratio of this long rod combo is 1.8 as opposed to 1.66 for the standard stroke 302.
So what do you think about going the long rod route instead of stroking?
Also if you go to Hawaii Racing and speak to Joe it could get expensive, but you only live once.
[ October 08, 2002: Message edited by: Chris Melia ]
