Well,,,,I took the Gt back for another run. Before I post the results I have to mention that after the last Dyno run I found Oil in my coolant /ubbthreads/images/graemlins/shocked.gif. Keep in mind I had 3100 miles on a brand new motor /ubbthreads/images/graemlins/confused.gif BUT, it still runs great, does not run hot and it does everything it did before!!!
Now the results,,, since the last run, I did the following borrowed Howard's exhust (Thanks bro). Re set timming to 36 degree total at 2800RPM (as told by FMS). Set A/F ratio to 12-1. Did only 3 runs.
275 RWHP at 5600RPM (Dynajet), (240 Dynamics)
308 FT Tourque at 3800RPM (Dynajet), (268 Dynamics)
Basically I gaind about 21 more HPs. We could have had done some more stuff. For example the A/F ratio drops to a shade below 11:1 when I get to around 4500 RPM.
Also, my standard GTD pumps puts out 2-3 PSI max. I purchased an equilvalant pump that puts out 6-7 PSI. But, I did not have the time to install it before the run.
I am fairly sure with more tweeking we can get to 285. There is one thing consistant about this motor though,, It takes a dump as soon as you pass 5600RPM.
Any way, I am posting this info incase anyone is interested. I have already started to e-mail Keith Craft, engine factory and 2 other outfits. It is pretty amazing when you tell them "YOUR ENGINE WILL BE REAR WHEEL DYNOED".
The response from some (the ones who have replied!!) is take our HP ratings and deduct 30%. So, if it is rated for 450HP, it will be 315HP at rear wheel /ubbthreads/images/graemlins/confused.gif /ubbthreads/images/graemlins/crazy.gif
Well, it will still be better than FMS, or will it?!!!
By the way RON, what do you think about having a section for Chassis Dyno (NOT "BS" FLYWHEEL) results? Hopefully it won't be just 4 guys posting /ubbthreads/images/graemlins/grin.gif
As an example, If I buy an engine tommorow from Keith Craft, 347/450HP, wouldn't the members be interested if this thing realy puts out?!
