Personal commitments, business / travel requirements and impending re-location have meant that I am reluctantly offering my current RF GT40 project for sale.
The car has a certain history, which appealed to me. Being a very early chassis (RF12), I believe it was originally built in 1998. This was destined to be Robert Logan’s personal race car, and so he paid particular attention to it with respect to its design and integrity. He commissioned Ross Holder (ex V8 Supercar chassis designer for Gibson Motorsport) to “tweak” the chassis design to add a couple of improvements. Better suspension arms and pickups, some additional rigidity, air jack mounts, steering rack geometry, etc.
The rear of the chassis has been further modified to allow for fabrication of a deeper diffuser under the transaxle, and to move the rear chassis rail up under the rear clip. This car has the 10.5" deep dish BRM style knock on wheels on the rear, that will actually fit under the standard width (Mk 1) rear guards, with shortened driveshafts (std driveshafts supplied)
The rolling package includes:
Modified race chassis, freshly powder coated Bright White
Complete 'Cobrex' body (front nostril section changed to single vent panel), hinged.
New Aluminium panel set, bonded and riveted into place
10 Point chro-moly roll cage
Front and rear fully adjustable race level control arms and drag links, ('over-engineered' 5/8" rod ends spherical bearings all round) all freshly powdercoated
All new High Mis-alignment spacers for all rose joints and spherical bearings
Magnesium race rear uprights, drive flanges and new bearings and wheel studs fitted
Standard RF front uprights, machine to accept Harrop hubs
Two piece 360mm Harrop front brake rotors and hats
Harrop front race hubs
Two piece 330mm Harrop rear brake rotors and hats
Brembo 4 large piston race callipers, all corners
Bespoke machined brake calliper 'dog bones' to suit
Willwood Race pedal box c/w brake bias adjust bar
17"x8" and 17"x10.5" (deep dish) BRM Style centrelock rims
Centre lock hubs, cast spinners, drive lugs, lead hammer, etc to suit above
245 (F) and 315 (R) series Sumitomo tyres
Avo adjustable dampers, spherical bearing mounts
Adjustable steering column and intermediate shaft
Quick ratio steering rack
Ford 302ci (EL Faclon 104,000kms), complete unit top to bottom, front to back
Complete engine wiring harness and ecu to suit
Kennedy engineering adapter plate, flywheel and starter
Audi 016, 5 speed transaxel, slave cylinder fitted
Stage 2, 240mm Sachs clutch kit (Kennedy's)
2 Reconditioned (std length) drive shafts
2 modified rear transaxel mounts, fitted with new nolathane bushes
1 Harrop Air Jack supplied
4 new stainless steel body latches
1 Windscreen
Windscreen fitting kit
6mm glass rear bulkhead and rear clip windows
Steering wheel (not intended for final use)
Various spares, parts and fasteners
Price AU$53k
The car is located in Perth, Western Australia.
Shipping can be arranged.
1 Windscreen
Price AU$53k
