Still thinking of forward mounting my battery in this spot as well for weight distribution and rear space.More components test fitted.
Im just outside of dallas tx.Nice progress Rick. Just curious Rick, what state do you live in.
Regards Brian
I will mill some aluminum hooks with some kind of quick release on it. They will mount to the lower front of the frame.Have you figured out how you are going to mount the front clam yet?
I want to conserve space in the rear, and offset weight.Still thinking of forward mounting my battery in this spot as well for weight distribution and rear space.
I think that one was made for a chevy van. Found it on ebay.That's a nice fit. I had to use a Volkswagen van booster and master.
Where did you source the cooling plates for the front brakes from?
Hello Rick can I ask your source and maybe a part number for the bevel gear?My big feet wouldnt go around the steering shaft, so i rotated the rack so that the input shaft is vertical. Installed a bevel gear unit to make a right angle away from the feet.
The coyote is drive by wire. I cut the gas pedal and made a linkage so that it acts as a sensor. Made a pair of aluminum plates to allow gas pedal adjustment in x and y so I can dial that pedal in for the right feel.
I bought it from ebay. Looks like they are no longer available. It was intended for a chevy van though.Hello Rick can I ask your source and maybe a part number for the bevel gear?
Randy,Looking really good Rick! I’m looking forward to checking it out in person in a couple months when I get home…
Curious about this bevel-gear system. Because one bevel driving another will reverse the direction of the input - there must be an intermediate gear.
BTW, flaming river does make these also, they are just very pricey.I bought it from ebay. Looks like they are no longer available. It was intended for a chevy van though.
