Rick Merz
Double bulkhead construction, I first modified and relocated my roll bar to the rear of the car by about 2" (post 93). I requested (from Fran and was delivered rather promptly) a new stock bulkhead (minus all holes including the rear window cut out) that I could modify to accommodate a Tornado glass rear window that will be mounted in a slightly lower position than the RCR window. I made a poster board pattern of the inner "A" pillar/roof profile that I transferred to the bulkhead and cut out, after a little grinding it fit like a glove. I then marked where the roll bar would be and laid out the rear window opening and cut it out. I then installed the inner bulkhead and started to design the rear bulk head.
I wanted the bulkhead to hide the ECU's and the radiator header tank since I prefer a cleaner look in the engine compartment and I will vent A/C to the ECU's to keep them cool. I used 1/8" poster board (heavy weight paper/foam/heavy weight paper) to mock up the bulkhead and roll bar cover. After getting the exact profile for the bulkhead, roll bar cover and inner panels that connect the two bulkheads together I printed out 1" x 1" graph paper big enough the trace all of the poster board cutouts. I then had to measure hundreds of points to 1/64" accuracy and input all of the points into AutoCAD to make a drawing that was used to program the laser cutter. The laser cutter's accuracy is so good that it can cut out even the small pilot holes for the 8-32 screws and 1/8" rivets that will be used to assemble the two bulkheads and inner panels. Next I had to bend a 5/8"x 5/8"x 1/16" aluminum angle that will be drilled on one toe for rivets that will attach it to the "A" pillar and drilled on the other toe to mount nut-inserts so that the bulkhead can be mounted to the "A" pillar/roof. I used a metal shrinker and stretcher from Eastwood to shape the angle to follow the "A” pillar/roof profile. This was my first time using a metal shrinker and stretcher and the final product turned out very nice with no gaps when installed. After forming and mounting the angle I attached all of the panels with 8-32 screws to the nutserts in the angle, I then removed the panels and sanded them to get them ready for paint which will take place after the car is painted.
