It doesn't matter what year the car is - and there are NO smog equipment requirements - none.
That isn't true. If you declare you are going after the body style of a 1970 vehicle,
you will have to have the typical equipment necessary for a 1970 vehicle. That is
why everyone says to declare it based upon a 1965 body style, where there are
no smog requirements. Here is part of Senator Johannessen's press release regarding
SB100 when it was put through CA Senate:
"SB100 requires a passenger vehicle or pickup truck that is specially constructed to be
inspected by service stations authorized to perform such functions. An emission inspection
will be based upon the engine model-year or model-year used in the vehicle. The owner will
also have the option of choosing whether the inspection is based on the engine or vehicle
model-year."
And, from the bill itself:
"This inspection shall be for the purposes of
determining the engine model-year used in the vehicle or the vehicle
model-year, and the emission control system application. The owner
shall have the option to choose whether the inspection is based on
the engine model-year used in the vehicle or the vehicle model-year."
"(2) In determining the vehicle model-year, the referee shall
compare the vehicle to vehicles of the era that the vehicle most
closely resembles. The referee shall assign the 1960 model-year to
any specially constructed vehicle that does not sufficiently resemble
a previously manufactured vehicle. The referee shall require only
those emission control systems that are applicable to the established
model-year and that the vehicle reasonably accommodates in its
present form."
As you can see, if you choose something newer than 1965, or the
body obviously replicates something newer than 1965, you must
meet the smog requirements for whatever year chosen/represented
initially. If not, you will fail the initial test. Only after "passing" the
initial test will the vehicle become exempt. Same goes if you smog
based upon engine year, but there are more stringent rules if you
go that route.
Here's a link to the bill:
http://www.leginfo.ca.gov/pub/01-02/bill/sen/sb_0051-0100/sb_100_bill_20011014_chaptered.html
