Malcolm,
If you can provide me with the x,y & z coordinates of your inboard and outboard pickup points (trailing and transverse), I'll see what I can do for minimizing your roll steer.
If you use a tape measure and plumbob on a flat floor at your wanted static ride height, you should be able to get accuracies of +/- 1mm. It might be worth trying this before you go to the expense and bother of parallel lower transverse links.
One of the problems in analysing the GTD rear suspension is that the lower radius arm is vertically offset from the lower transverse arm on the rear upright and this means that the trailing arm pickup point moves through a complex curve as the suspension moves up and down.
The curve is influenced by both the upper and lower transverse arms. The location of the front of the trailing arm is critical to matching this curve, adjusting castor doesn't seem to be as effective.
The adjustments would mean you have to build a couple of offset u-brackets plus shims. If you want to try this, it would be useful if you could measure the roll steer before and after the adjustments, to ensure we are on the same page.
