Trev,
Congratulations on the engagement. You are about to enter a new and exciting (if not challenging) part of your life. You are making good progress now and you should have the motivation to finish things up. I have to make an assumption here and that is she is behind you on this project!! Don't let the tediousness of the build or her occasional nagging get you down. They are all things to work through.
Let's hope it stays that way as if all goes well I might build another car when this ones done
I like the look and plan to do something like it myself, I believe Tornado don't suggest panelling the engine inner panels as it just adds extra weight and is a water trap but if the underside is open or has drain holes I don't see the issue with those. Just remember that you'll probably need drain holes front and back as the car should have a nose down attitude normally but may be parked on a slope!
