I'm having trouble breathing! When I first put my car on the road in 1999,I fitted a PCV(the right way round!)between the Holly 600 and the RH rocker cover, with an open filtered breather cap on the LH side. I always felt this was unsatisfactory - lumpy tickover/slight oil leakage from the cap.A couple of years back I changed over to an open breather to a catch tank on the RH cover.
Last weekend I did a high mileage trip and as I got home, I found that the engine stalled at hot tickover. I discovered that the end of the breather pipe was just below the fluid level in the catch tank(whoops - who's a dozy git then?). Interestingly, the accumulated fluid(about a third of a litre)in the tank was largely water, plus a little oil, but there is no sign of water in the oil system (condensation?).
However,even before this silly event, the breathing still appears poor as I still get slight oil blowout/leakage from the filter cap.
All ideas would be welcomed.
