C middy Sep 14, 2008 #1 Hello Is the distance between shaft centres of the type 930 transaxle the same as the type 915 one (76mm)? If not, what's the distance? Thanks
P Paul Bearman Sep 27, 2008 #2 Croc, I assume you mean the dimension as indicated in the attached CAD drg? If so, both my 930 'boxes measure 75mm. Attachments 930 gbox.pdf 930 gbox.pdf 94.1 KB · Views: 352
