Lynn Larsen
Lynn Larsen
Everyone,
While cleaning out my office (about 4 years over due- I found my second windscreen though!!- does that give you any indication of how overdue it was /ubbthreads/images/graemlins/blush.gif), I came across a formula that VintageAir had given me with which to check the amount of freon (134a) in your system. When setting up the system, I was told to put x pounds of freon in. This amount was given to me before I had told them much beyond the fact that I was using a Sanden 505 for 134a. When I balked, mentioning that I had a mid engine car with at least 12 ft. of lines between the compressor, condensor and evaporator and saying that there had to be a more scientific way to determine if the proper amount of freon was in the system, they gave me this formula:
Run the test at 1500 rpm. Place as strong a fan as you can infront of the condensor coil. Close doors and windows and put A/C blower on medium.
High Side Pressure should = 2.35 X ambient temp in ºF (160-250psi)
Low Side Pressure should be between 6psi and 12psi in a steady state (once system stabilizes.)
Center Duct Temp should be 36ºF - 46ºF (This will vary depending on the distance between the evaporator coil and the outlet where the temperature reading is taken and how well insulated, if at all, the ducting is.)
I am attaching the VintageAir Troubleshooting guide (M$ Word doc).
Lynn
Lynn
