Depending on the path your lines take, air can be a pesky bugger to get out completely. Sometimes it takes several bleedings, over time, of 2x to 3x of the total amount of fluid the system holds to get it all. If you have any rubber in the plumbing, I would replace it with all teflon lined SS lines and AN fittings. Moisture can pass through rubber lines, believe it or not, over time of course. (Same is true of brakes as I learned the hard way in my failed attempt to use a silicone fluid: big mistake.) Unless you are running carbon discs on a hard core racer, Ford High Performance (DOT 3 I believe) brake fluid is what most of the more casual racers and performance minded people in the know run after having tried all of the other gimmicks. Unless your components were designed for something else, I would think this would be optimal in your clutch lines as well.
PS: I think the brake and clutch lines should be completely flushed once a year or every other year at a max. I just thought of something, you aren't using one of those plastic hand pumps on this are you? If they had a good solution to air leaking around the threads of bleeders they would be OK. But, no matter what I have tried, I have not been able to guarantee that this doesn't occur. Backwards pressure fill is the only other method, besides the tried and true fill the reservoir and have a buddy pump, that I know works, period. Indeed in some systems, this is the only way you can fill it and be sure of not getting air into the lines; motorcycles are famous for this. I have seen where guys use air pressure to assist the tried and true method. If you have time to make the a sealing pressure cap for the reservoir or can buy one, I don't see this as a problem either. Just make sure you don't let the reservoir go dry, of course
Speed bleeders DO work also and make the tried and true method a lot easier.
Lynn
(Tim, don't take this the wrong way. My descriptions may seem like you don't know most of this already, but they are meant more for the nubee who is reading this sometime down the road. My wife let me know the other day that it is sometimes taken as condescending and that is the last thing I want to do.)
