Custom cable shift adaptor for Quaife QEB62G Transaxle by CNC Performance
Hey Folks,
I got in contact with Corey at CNCPerformance.com in Utah, I was able to send him my Quaife QEB62G transaxle and he was able to R&D a cable shift adaptor for these transaxles! It came out amazing. So now there is a solution for the Quaife transaxle. It's a beautiful piece of kit. Contact him at CNCPerformance.com
Martin
I just finished putting one of Corey's shifter assemblies on my RCR with a Quaife ZF. It was a pretty straight forward installation. Adjusting the cables and shifter took some fine tuning, but all works well. Once my car gets the wheels aligned, it will be time for the first drive.
Martin
Martin could you mention what length of cables you used and where did you pass it.
The overall length was the same for both cables. Total length was 79.3" and the face of bracket to face of bracket distance was 64". I ordered my cables thru Corey and he only needed the distance between the brackets to place the order.
I routed both cables thru the firewall above the tunnel and next to the passenger seat, which is currently removed (see pics). And then routed one cable above the motor mount and the other below. Since the termination of one cable is higher than the other on the transaxle, this seemed like a good solution.
