Terry Oxandale
Skinny Man
I've seen this part before, but only once, and cannot remember what it was called, or where I found it.
The piece is a stub welded or fitted against the side of a tube that fits the OD curve of the tube, but has a flat end in which a bolthead can rest against. Basically, this would be used to provide appropriate support for a through-bolt, through tube, for bolting something to that tube without isolating all the bolt's compressive force on a very small portion of the OD curve of the tube.
If anybody can suggest the correct naming of this kind of part, then perhaps I can do a proper Google for it. Otherwise, I'm left which trying to make them myself.
