Help- wheel well liners
I know it has been posted and that several build threads show it... but I cannot get the search engine to direct me. After frustrating my self searching with no luck, can someone direct me to where the wheel well liners go. I am lost without some pics. :huh:
Hi Michael, Bill Modified his a lot, they look like they will do the trick but are not installed as they were intended.
Cheers,
Grant
If anyone is interested in a template for the rear vertical wheel well liner (that travels from front to back-not the rear rounded liner), I would be happy to send that to you- just pm me with your address. As you know, this supplied piece does not approach fitting the street tail. The top of it needs to be shaped significantly different, along with also needing to be extended. I have created the pattern for the street tail.If you want or need it, I would be happy to send it your way.
