Olds column pin out and wiring
Kyle
GT40s Sponsor
Hey guys, I working on a new project which is a coupe 65 from FFR. Decided to use a similar idea to the SLC with olds column which has worked out nicely. I’m to the wiring stage and I didn’t write down any of the wiring I did for my SLC. Does anyone have a detailed more description of how this word?
For instance with the corner lamps it’s a little confusing with the feed vs output. Would pin outs B/C be the power coming in to the harness for the lamps, and then F/G the power out of the harness to the bulbs?
Are all the grounds needed? All the power feeds?
D = Ground (Black Wire)
F = Yellow/Red
G = Yellow/Black
K = Blue/Red
L = White/Green
R = Blue/Black
W = Ground (Black Wire)
X = Ground (Black Wire)
Z = Ground (Black Wire)
There also needs to be a diode installed between K (Blue/Red) and L (White/Green). The stripe on the diode (cathode) needs to go towards K (Blue/Red). Pretty much any diode will work because the required current is very small. A 1N4001 diode works fine.
Here's a pic showing the connector pin locations, but they're also marked on the connector if you look closely:
Kyle
GT40s Sponsor
I played with it a little last night and figured out the turn signals. The running lights and headlights still perplex me tho.
