I am in the phase where i am starting to wiring the looms for the car, power, lighting, auxiliary etc.
But i haven't decided whats best yet in two regards and would need some of your thoughts and pictures please.
1. Engine harness, wich way to approach the engine? Was thinking about approaching from the rear side at the bellhouse to get a cleaner look, but the heat from the headers is an issue.
2. I will run separate ignition coils, was thinking about putting them on each side of the oil pan on the chassi and then just let the ignition cables connect to the engine from underneath, this would mean less heat for both coils and cables. The only thing talking against this solution is the instruction for EFI system that states that the header ground wire from the coils need to be as short as possible to the head it will ignite into.
Would love to hear your thoughts and ideas, and also see some lovely pictures of engine bays with different solution for both engine harness and ignition solutions with separate coils.![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
The general concept about the enginebay is that "neat and invicible", meaning i want as little as possible of wiring, and other cluttering things as brake lines and hoses to be visible.
I have already gone thru the pain of having all brake lines routed behind panels.
The same will be done for wiring and hopefully hoses too.
