Hello. I'd like to hear your opinions about the Quaife QTEK 6-speed. The pic below shows that, unlike Porsche gearboxes, the side plate is on the left side so the box doesn't have to be inverted for mid-engined configuration. Can be had in either H gate or sequential. Price 7,500 GBP for H gate. Specs:
Quaife QTEK 6-speed H pattern transaxle gearbox is a universal fitment for mid or rear engined applications.
Quaife QTEK 6-speed H pattern transaxle gearbox is available in two versions: dog engagement with sequential shift, or H pattern with helical gears.
Gears are available in straight cut for race use, or helical cut for road use.
Quaife QTEK 6-speed H pattern transaxle gearbox has a Quaife ATB differential included as an integral part.
Quaife QTEK 6-speed H pattern transaxle gearbox can be run in standard or inverted fitment, depending on the application. The oil pump is incorporated within the transaxle unit.
With the Quaife QTEK 6-speed H pattern transaxle gearbox the crank centre line can be above or below output flange.
The final drive uses a spiral bevel gear.
Quaife QTEK 6-speed H pattern transaxle gearbox includes mounting and suspension pick up points.
Over 15 types of bellhousings available to suit different applications.
Maximum recommended power 450bhp.
Weight approximately 65kg.
Quaife QTEK 6-speed H pattern transaxle gearbox is ideal for applications such as Lotus Esprit V8, Ford GT, Ultima, Noble etc.
Various ratio options. Base set race:
2.600, 1.933, 1.533, 1.250, 1.043, 0.880
Base set race:
3.000, 2.000, 1.458, 1.143, 0.921, 0780
FD ratios:
3.700, 4.111
Base set race:
FD ratios:
3.700, 4.111
