I have a kind of specialized question about best practices for engines outfitted with a remote oil filter and cooler. This relates to my Miura project car that is using a Gen 2 Coyote engine in it. Due to inaccessibility for the regular oil filter location and a very tight engine room which will be hard to keep cool, I am outfitting it with a combination remote oil filter and cooler system. This is the system I'm using: MMR oil cooler kit
I saw in an instruction manual for similar Ford Performance setup for Coyote engines, it showed using a special pressurized bottle of motor oil to "pre-fill" the hoses, filter, and oil radiator and thus purge the air from the remote system prior to engine startup. This manual explained that on older engines (Windors, FE, Clevelands, etc.) with a distributor, the best practice was to remove the distributor and rotate the oil pump directly to pressurize the engine and thus purge air from the remote filter and cooler. Since the Coyote has a crank driven oil pump, it was necessary to use an external pump to accomplish the same. The instructions were to remove the oil pressure sensor, attach a hose from the pressure bottle to that port and then pressurize the oiling system until the air was driven out through the bearings, etc.
This all seemed reasonable and makes sense to me. It does however, raise some questions in my mind about best practices for similar setups:
- Is removing air by pressurizing the oil system just an initial setup thing, or is this the best practice to do this for every oil change?
- If possible, should the remote oil cooler and filter be located/positioned so that the oil will drain from them and associated hoses during an oil change? If so, then the answer to prior question is likely to be air needs to be purged in both situations as quite a bit of air will likely be present.
- If purging air from remote oil system is a re-occurring necessity, is there a best practice for the plumbing that will make this easier and result in less mess? It seems like screwing an oil sensor out and back in is neither a simple nor spill free way to do this. Maybe some sort of 1 way valve could be tee'd into the plumbing for connection of a pressure bottle. Or maybe that's overkill, how about a fill port on the uppermost hose/pipe so the air can bubble up and out of the majority of remote system? I did see on a Porsche site talking about adding a remote oil system to 914s, the recommendation to remove coil wire and crank motor till oil pressure showed on the gauge. With the newer coil on plug ignition system used in Coyote, this simple "old school" approach isn't available.
