Question for GT-R builders on front suspension parts to remove spacers
Robert Roth
Hi - my GT-R kit should hopefully be arriving soon and I've been reading essentially every build thread I can find ( amazingly impressed by the capabilities of the builders in this forum!). One thing I know I will need to do is change out the front suspension components to allow for removal of the spacers / adapters used on the front wheels - both for easier steering and here in Pennsylvania any 'wheel spacer' > 5mm in size will prevent passing technical and safety inspection to get registered. I've found these described and pictures of the changes that H came up with, but can't find out really exactly what parts I need to do this change ( believe they are McMaster Carr and Speedway, but haven't had luck identifying exactly which ones). With H no longer engaged, is there any chance that someone from the forum who's done this could share with me the part numbers needed to make the change?
Thanks!
Robert Roth
Actually - should have read further on Kurtis's thread - found the instructions and part numbers there - apologies for unneeded post .
Joel K
Robert,
It is fully documented in Kurtiss’s build post #256 with an attached pdf…
Johan
Just watch out if you are planning H’s mod of moving the upper shock mount.
There is a chance that the lift pucks don’t have enough room if you’re planning to use it.
The Ramlift might fit but I don’t think the Viair fits.
Robert Roth
Thanks - that is very useful information to have.
