FS EU Renault UN1 Transmission (UK)
Originally from a Renault 21 Turbo, it was rebuilt by Chris Cole 3000 miles ago and fitted my ‘40. It has been replaced due to a loss of oil, which damaged a couple of bearings and an upgraded transmission being available
I had to use few parts in my refit (input shaft sleeve & reverse switch), but overall it can be easily can be rebuilt/reconditioned by a specialist with a few readily available new parts (mainly the 2 rear bearings and 5th gear syncro cone). The pair of gears for 5th were also damaged, but I will include the original UN1-13 ratio gears, as I was running the higher ratio
£500 plus shipping if required. Item located in Norfolk
Andy
