Recently I noticed there is air (vacuum) being pulled though one of the end bearings on 1 of the IDA's. This got me to thinking that maybe the inner 2 bores for the throttle shaft in the aluminum body of the carb may need to be resized. These were used carbs that were rescued from some VW sandrail guys. I realize .5 mm oversize shafts are available (seemed very pricey!) and it got me wondering if the inner bores could be resleved (like brass valve guide liner), and retain the OEM shafts. I have double shielded bearings to replace the OEM open bearings and leather seals. What do you think? Has anyone done this procedure?
