Hi Simon,
As a VERY rough guide the angle of the lower wishbone would be angled down and the upper wishbone angled up at a steeper angle (about twice the angle of the lower. The angle is measured from the centres of the pivots not the metal wishbone tubes themselves. The idea is that as the lower wishbone moves upwards in bump the outer pivot moves away from the car centre line and for the upper wishbone the outer pivot arcs inwards towards the car centre line. So the lower moves out and the upper moves in thus increasing the amount of negative camber. When the suspension droops the opposite occurs. So when the car loads up the outer wheel in a corner and the car rolls the suspension puts in more negative camber to keep the tyre flat to the road. The best way to find out is to make a cardboard model or use a computer suspension program to see what happens as the suspension rises and falls. The amount of camber change has to be tuned to the roll stiffness so as to keep the tyre at the right angle to the road.
The quickest way is the ask Mick Sollis as he has worked all this out. It seems to work well as Mark Hales was very favourably impressed with the handling of Glen Mason's SGT.
