steering rack - KVA MKI chassis type "C"
Laurent
Hi everybody !
is somebody know which steering rack we need in a KVA MKI chassis type "C" ?
thanks !
laurent
Mike Pass
As the early KVA used the complete front axle from a Fotd Cortina Mk3 I would think the C type rack was the same. Check images on Google.
Laurent
Thank you Paul, Graham & Mike ! i will disassemble mine and look at the references to understand what it is and what is wrong...
( The steering angle of the car is absolutely zero..)
Mike Pass
Check that the rack input shaft is turning when you turn the steering wheel. If the input shaft is turning the problem is in the rack. If the rack input shaft is not turning the problem is the steering column.
