Superlite Coupe - SLC - Street Tail - $85,500 **SOLD**
Status
Not open for further replies.
This Street Tail SLC has clear title, licensed, registered & driven on the street. This car has NEVER been tracked or abused. I am the original owner.
Listed for sale with an asking price of: $85,500 USD (No trades)
Since the "rollers" are fairly "standard" I'll list some of the items that may differentiate my build from others.
  • Later designed dropped floor under seat area
  • GM New crate LS376 (480hp) motor with GM ECM/wiring harness
  • KOSO Gauge Cluster
  • Isis Electrical system
  • Tilt/Telescopic steering column
  • Advance Key push to start system
  • Tires: Nitto Invo’s Sizes: 275/35/18 & 325/30/19
  • ForgeStar Wheels
  • Brembo Brakes with dust seals
  • Optional emergency brake system
  • LS7 Hydro-formed exhaust manifold to custom pipe to Hushpower II exhaust mufflers
  • Painted body (Deep Cherry Red with Corvette “hammered” silver stripes)
  • Adjustable pedal box
  • The preferable - Porsche G96/50 (996 twin-turbo) trans-axle – complete rebuild by GBox - inverted box, cooler in & out. Quality rebuilt units equipped as mine are now in the $11-12K plus range – Final drive: 3.44 with 6<sup>th</sup> gear ratio of 0.75
  • Gikken OS LSD (limited slip differential)
  • Kennedy Flywheel, Kennedy stage II clutch kit, disc and throw-out bearing, Bosch starter, 9 clutch bolts, Kennedy pilot bearing kit, flywheel bolt kit, and GT2 slave cylinder
  • Upgraded Maradyne Fans radiator coolant fans
  • Remote battery cut-off switch
  • QA1 adjustable shocks
  • Upgraded Rear Suspension Springs
  • Momo Steering Wheel with adaptor
  • Dakota digital GPS sending Unit
  • RaceLogic Traction control system with in-cabin digital controller
  • Tillet B5 Full Carbon fiber seats B5/C/GRP/SU - with Dinamica® suede covering)
    TB3 Floor mount brackets B4 (pair)
  • Custom Coolant expansion tank – IIRC approx. a dozen were made
  • Optima Battery
  • Five point harness system for driver & passenger
  • Lift/surge tank system
  • Heat and A/C – fully operational – (Vintage Air System with upgraded interior 4 knob streamline panel anodized blk. #491229)
And other items I have likely forgotten about.
Approx. 2600 miles all on country back-roads - the car runs strong with no issues.
The car was completed, titled and registered (all clear) in 01/2013
Located in middle Virginia, USA
For quickest contact: msslcva at gmail.com
Thank you – Mike
<!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]-->
Re: Superlite Coupe - SLC - Street Tail - $85,500
Really nice car and a great price too....don't forget the SLC makes a good track car too with little to no mods...
I would love to be able to buy your car. But I'm in California and they are making it really hard to bring in a car from out of state and registering it here.
Par
Thank you all for the inquiries. The car has been sold.
Status
