Hi Neil,
These are the specs as issued by JW Automotive Engineering Ltd, hope they are of some use.
Camber Angle* : Front 20 minutes negative.
Rear 10 minutes negative.
Toe-in *: Front 30 minutes toe-in
Rear 20 minutes toe-toe-in
(10 minutes per wheel)
Castor Angle: Front 6-6 1/2 degrees
(non adjustable)
Rear 7-8 1/2 degrees
(adjusted to give minimum toe-in in bump and rebound positions)
Toe-in change: Front:
Static bump-15 mins max ideal nil.
Static rebound-20 mins max ideal nil.
Rear:
Static bump-10 mins max nil ideal.
Static rebound-15 mins max nil
ideal.
Ride heights*: Front: 4.125"
Rear: 4.375"
*CAMBER,TOE-IN,RIDE HEIGHTS ALL MEASURED WITH FULL FUEL TANKS.
