UK KVA "C" rebuild 2023
Hi all,
Just purchased what I believe to be a "c" chassis KVA, that has sat still for 28 years.
I will post some pics , and would appreciate any information on parts that are used and pointers as to what might benefit with upgrading.
My aim is to try and replicate a original looking car (lights/indicators/seats /interior) but I know its always going to be a replica.
Looking for a meet with fellow owners in the south of England so I can pick over some details of other peoples cars!
What are the differences between a 1988 KVA body and a original, as I was led to believe that the bodys came from a original GT40 mold, but have read elsewhere that they are incorrect.
Where are the front side repeaters placed originally if they had them?
Not looking to make SVA compliant as its already reg
istered!...so many questions!
TIA,
Ian.
Brian Kissel
Quite a find there Ian. Perhaps you should join the enthusiasts club over there. There are a lot of very knowledgeable people on that side of the pond.
Good luck with your quest.
Regards Brian
Mike Pass
KVA is from Kenneth Vincent Attwell who was allowed by Ford to create a replica. He made several alterations to the original body shape which is why most replicas have the ridge line at the top rear of the side windows. The C type chassis is OK. The slight issue is that the chassis tapers in at the front so the wishbones are of unequal length. This means that on full lock the tyre can touch the inner wheel arch at the back.
The C type uses Ford Granada uprights at the front with fabricated tubular wishbones and coil over dampers. The rear uses trailing links with reversed lower wishbone and a fabricated upright with Ford Granada Mk3 hubs which are 5 bolt. The Halibrand style 15" wheels have a limited choice of tyres. I would change the concrete tyres you have for Avon cr6zz which are the best but not cheap!
The KVA body panels are good and like the GTD bodies.
You have a Renault gearbox which may be the 369 box or the UN1, There is usually a metal tag on one of the rear cover bolts with the model number stamped into it. The clutch is probably the Renault one. The box is attached to the engine with an adaptor plate.
The engine looks like a Rover V8 and probably has a 390cfm Holley carb with vacuum secondaries. The carb will have a List Number stamped into the choke tower on top of the carb so you can look up the specs and rebuild kits on the Holley list numbers info.
The seats look to be Corbeau which don't look very original.
There is a right hand rod gearchange set up.
I would suggest a good check of the brake lines and also the fuel lines which may have deteriorated. Also the brake pistons may be stuck due to corrosion. The brake calipers and seal kits are available from Burton Power as are the hub bearings.
You have a good base to start off.
First off follow JPs suggestion and join the GT40 Enthusiasts Club. There will be a group near you with monthly meetings vwhere you can meet up with other owners and get access to a lot of help and knowledge.
Post where you are based as this will help to suggest local help.
Well 18 months on, and there was allot of 80s quality inside the car... The more I removed the more I needed to remove and remedy.
Engine and box is rebuilt, chassis has had bits cut out and new put in.
Panels remade, tanks modified, and everything overhauled it replaced.
Hoping I'm at the bottom of the bell curve of dismantling, even ended up moving the pedal box .
Hoping to finish with a quality looking and driving car .. In the next 12 months
Well cold dark nights means progress in the garage, gone freestyle with the interior. When the temperature warms up I can paint some bits and start to reassemble it.
Big job Ian, but it looks like you’ve come a long way. No way to get through a huge project like that without perseverance and commitment…kudos!
Bit the bullet and bought a purpose made radiator as the original brass one was going to cost more, be less efficient and heavier. That has lead to removal of the last few panels left attached, so panel number 76 and 77 made
Time marches on, and some visible progress made, spring summer and now into Autumn 2025. I managed to get the primer and paint on while temperatures are on my side!.
Wiring to do, Fuel to check and inertia switches to mount. Almost evetything is trial fitted, with the exception of the engine with its ancillaries. Then the exhausts...to make.
Some days I walk into the toy box and love it, other days its a PITA to look at!
Fortunately there are other running toys to distract me :)
If that off white is your final color, I approve.
Coming on nicely! I’ve just made a start on resurrecting my GTD - less years sitting so I’m hoping it won’t be as involved……
If you are keeping the Holley, I just finished refurbishing mine so can point you in the right direction for parts etc.
Hello Ian: Very nice indeed. I admire your persistence and the fact that you appear to do (a lot of) the work yourself. Refurbishing many of the components the car came with not only helps the budget but also will result in a fairly genuine KVA replica. Looking forward to more news from you. I bet you'll be on the road with it come next year.
Best wishes, Walter
Hi all,
Not looking to make SVA compliant as its already regView attachment 129501View attachment 129500View attachment 129502View attachment 129503View attachment 129504View attachment 129505View attachment 129506View attachment 129507View attachment 129508View attachment 129509istered!...so many questions!
TIA,
Ian.
Looks real great! Congrats on your purchase
Today.. electrical archaeology , I've been holding off of this in fear.
After changing a couple of bits that fell apart in my hands.. I've discovered what some of it does, and no smoke has yet to escape
Winters here, cold grey and wet!...but the KVA is nearer the ground than its been for 3 years!.
Engine 4.6l, is looking to join forces with the UN1, and then more fun to had with discovering things I used to know, and have to relearn!
