Valve covers
I’m considering installing cast aluminum valve covers on my 347 Ford . I am currently running 48 IDA webbers . I know the flange is bigger or wider on the aluminum valve covers then stamped steel. I’m concerned that the flange will hit on the Weber manifold. I don’t know if there’s enough clearance has anybody had any experience with this . My heads are DART. Thank you in advance
im using cast covers.
I have attached a couple pictures that may be of use.
Jerry
