What's wrong with this picture
Terry Oxandale
Skinny Man
Just finished dropping in (using the hoist) and bolting in the block and transaxle after fabbing up the mounts. So is this too easy?
My first guess at what is wrong.
I recon you may need more room around the front Terry.
Hang some parts of the front before you make those mounts.
Jim
I'm with Jim, looks like the package needs to come back 4-6" to line up the axles and give you plenty of room in the front, It does look like an easy fit with lots of room around the eingine, its amazing how it dissapears once the heads and Headers etc start taking up space. Are you going for under slung or over the tranny exhausts, I like the look of over the trans headers and would like to go that way with my build , but the heat close to the bodywork would be an issue for me, Anyway Terry, its looking good as always, keep up the work mate. Cheers Leonmac.
Thinking about it Terry drop the heads on it as well.
If the alternator lives in the valley put that on because you will need to clear your back window frame work.(the one behind your head).
Leon is correct you run out of space,slap as much as you can onto that engine so you dont shoot yourself in the foot.
Jim
