ZF gear shifter movement
Hi gents,
We are currently preparig to fit the Quaife ZFQ gearbox.
As I have to lay out the shifter right now, I should know which necessary movements the selector shaft on the gearbox has to make.
I could measure it, but I'm sure, somebody already did this. As far as I know, the movement should be the same as for the ZF, as the ZFQ is just a bolt-in replacement.
Can anybody of you provide this info (angle and travel for each gear)?
Trevor Booth
given the technical expertise of Quaife why would you not ask them ??
I can give you the values for a ZF but that may not be the same as the ZFQ
The zf gear stick plate can be used for the zfq installation as the movement is almost identical my zfq was almost an exact swap for my zf installation with only very minor alterations. regards Mick.(southern GT)
Trevor, when I picked up my ZFQ at Chris melias place, he didn't have the numbers at hand. Instead of troubling him, I wanted to ask if anyone else has this numbers too. Chris is a busy man..
Thanks, Mick.
