Well, we finally got the car out for the inaugural drive!! A long time coming!
The cam that was in the engine we had to pull out and I ended up getting a cam from Cars by Carl that had more lift, maybe 10 degrees less duration, but a wider lobe separation. Plus, I put a large port dual plane intake on it instead of the Victor. The bottom line is that we didn't have trouble getting the car fired up and idling although it is a lot of work to swap the cam with the engine in the car.
From left to right, Jeff G, Sumner S, and myself on the right. We took the car out for a short drive to a local BBQ restaurant, scarfed some food, drove a bit on the highway, and met up with Jeff Young who has a 72 Charger 440 4 speed.
I'll have more driving impressions later, but there is one issue I need to fix straightaway - the brake pedal feel. The car is using the stock master cylinder and has rear Ford Explorer brakes. Everything works, the car stops and so on, but the pedal travel is incredibly long. I'm betting getting a master cylinder from a Ford Explorer will a) bolt on although may require fitting changes, and b) solve the problem and bring that pedal up off the floor. The brake system is absolutely properly bleed and solid with fluid, no problems with that at all.
Anyone have any experience with alternative master cylinders on rear disc brake conversions?
****EDIT - Another piece of info - I am no longer using the stock Torino proportioning valve. I tossed that and am running a line straight to the front and one to the rear (obviously teed). The rear line has a valve on it that I can reduce line pressure. We've done this on countless race cars with no issue at all, but they were all Mustangs, Miatas, Zs, RCR T70 and they all had masters that were designed for the car. The Torino started life with disc fronts and drum rears and is still using that master, which is why I tihnk it needs swapping out. I knew it'd need changing but to what is the question.
