Re: Audi 016 goes Bang!
Don't disregard the 930 option. Probably cheaper than a G50, and about 30+ lbs lighter. Not to mention stronger. And by all accounts parts and alternative ratios are cheaper.
With a 930 in the hillclimb situation you will probably only be using first and second, a nice easy forward/back change. Second will have all the snot you want and you will probably only be able to put it all down in a straight line anyway! So there is probably nothing to be gained from the shorter G50 2nd. The 930 first will be more useful and the taller 2nd means you won't be constantly doing 2nd/3rd/2nd gearchanges. However the G50 2nd/3rd/4th spread may be better for your track work.
Just a couple of thoughts to throw at you....
