Someone argued that the Feds didn't follow proper procedures which caused the fire.
Correct, the Feds did not discharge the Battery after the Crash, which is equivilent to the Feds not draining a Crash vehicle's fuel tank after a test crash (which is standard procedure). Would the Media be all over this story if any ordinary fuel tank caught fire because the Feds didn't drain it per operating procedure? NO! The Media is in business to sell Newpapers/Magazines/gain Viewers to sell Advertising. The truth is a by-product!
Guys, sense check-
1) The Battery Pack is in the center tunnel between the seats on the Volt. The test is a 45 MPH side impact. If you were in this car and the Batteries were damaged, the batteries burning two weeks after impact is the LEAST of your worries! A 45 MPH side impact is not a fender-bender.
2) The followup Fed test were conducted on Battery Packs ONLY, not Volt cars! The Packs were impacted, then rolled over. Once again, if you were in a car with these Packs, the vehicle igniting WEEKS later would be the LEAST of your problems.
Now GM is willing to buy back Volts, kind of like never selling the EV1 rather than having to admit failure on that one
The automobile industry will often introduce new technology in a small test fleet (rental cars, taxis, police fleet-it's called "Captured Fleet") in order to observe them closely. This is why the EV1 was leased, because GM had no end of life experience with the batteries and inverters, owning them gave GM the opportunity to perform a post-mortem when the cars were done, to further their learning. The EV1, which was a success because it helped GM gain knowledge in an area it had none before (there is no high voltage inverter in your regular passenger car-no one in GM at the time had the experience in inverters), and it did what it was suppose to do.
Darnel
