Ian,
The filler and the pipe in the tank are both 2 inch OD. I did get some 2 inch OD exhaust pipe and was fooling a little with trying to cut that before I decided to wait on the custom shop thing to try that out, as well as sending a query to RCR (have not heard from them) on availability.
Will certainly use the plug the neck and use the shop vac advice if I end up cutting.
I have been working on forming a spacer from some 5 inch wide 1/4 inch thick AL plate that I have. Figure that is a good backup. It is hidden on the final, so if the circle is a little rough, no big deal. Now if only I could find a blade that lasted for more than 10 inches of cutting with my scroll saw......
