I will be able to trim the lower opening of the front clam on the passenger side about an inch don’t matches the driver’s side (that is currently about an inch from hitting the rad support). This will give a few more degrees of rotation.
Interestingly, as things get bolted down, instead of clamped, body lines and gaps start to improve. Perfect example of this is where the back of the clam meets the lower windshield area of the spider.
