I have recieved from RCR 4 wheel spacers 4x35mm.
For the front, I need to be reduced them to 18mm. (I've got 10" wide front wheel). It will be done soon.
For the rear wheels, 35mm is almost perfect, but I will not be able to install correctly the big nut in the center (only few milimeter). I would not be able to tork it safely.
I need to change the design.
I will add a spacer on the hub.
For this I need to change the wheel studs.
Does any one have a reference of the one used on RCR kit ? (I heard it was from C5 Corvette)
Where can I found longer wheel studs (1 inch more)
