So, I sheared the input shaft of my bastardised 944 S2 (3L Motor version) tansmission the other day. It lasted 5 years of hard competition work, so can't complain really. Was hoping it was clutch splines that went, but no luck...
So, ideally I want a 944 S2 input shaft. I can then get that machined and splined to work with a clutch and off we go again.
Failing that, I guess a complete 944 S2 trans, though may consider a 944 turbo trans. They are basically the same thing, but turbo has a taller final drive, which I'm not sure I want.
Also may consider an 01E 6 speed, as I know they can be adapted to my current setup with different clutch, flywheel etc. Bit more work needed, but I guess nothing is easy!
Come at me with what you have. I'm in Western Australia, so nowhere near you no doubt...
