I have a whopping 40 miles on the car. I’m struggling with getting into first and second on a downshift. Up shifts are fine. I have the old shifter so when I set my cables on the shifter arms of the Graz, I set the shifter in as neutral a position as it would allow and the transmission in neutral then adjusted the cables to fit their respective mount points on the gear arms of the Graz.
Since the pattern is so tight, there must be a more precise adjustment I don’t see. So what have you guys done?
Dan
Dan
