This winter I upgraded the GTD brakes to Wilwood superlites 4-pots with all equal size caliper pistons. I also installed a Wilwood pedal assembly with balance bar. I use two .75 MC's Pedal pressure feels good and on the brake testbench I get the correct numbers. On the road the rears seem to lock up to early under havy braking, resulting in slightly braking away from the rear. Even with the balance bar completly set to the front. Therefore I assume I need to change the front M/C. Am I correct that I need to fit a smaller M/C for the front like a 0.70 MC?
Best regards,
Gerard.
Best regards,
Gerard.
