G
Guest
Guest
The built in bias control in the Corvette master cylinder, or most any semi modern master cylinder from a front engine car, keeps the pressure down on the back brakes and puts more pressure where the weight is. With GT40s we have to do the opposite, so we put the bias adjuster on the front brake line to hold it back and put more on the rears. This seems to me to be fighting the master cylinder's built in bias. This system seems to work on several cars: ERA, DRB, Sabre to name a few.
My cousin-in-law, Chuck, is a good ole country boy who lives on Lake Okechobee in Florida and is also the head mechanic for all of the county's equipment down there from police cars to bull dozers. I posed the issue to him. He suggested that I try just reversing the brake lines in the master cylinder to let its built in bias work for me rather than fighting against it with an auxiliary bias adjuster. It is possible that, alone, the built in bias might be too strong in the back this way, but it should be closer than the way it is done now or so it would seem. This might require dampening the rear brake lines a little.
Knowing that dampening the front brake line in standard position has worked for various cars, I haven't tried Chuck's suggestion, but I still think about it from time to time.
Any opinions on this. (Some of you who have been around a while might remember this; I think I posed this a long time ago. But then again, at my age, I am not sure. Anyway, I don't recall that there was a clear cut answer if I did
