Clutch plate ..
I need a spring type clutch disc for my 012 transaxle. 23 splines. My input shaft measures .936, 228mm would be nice but I can use up to 11inch dia. and modify. I have looked for hours with no luck.Thanks
Hi Ron, i sourced a rx7 mk 4 pressure plate and clutch disk for my project to go into a 016 box i had 3mm skimmed from inside the bellhousing and the clutch people changed the splined centre section of the disk to suit the input shaft, about 30 splines, i think the 012 and the 016 bellhousing are almost identical.
Pressure plate measures 293 and disk is 235 that was the biggest i was able to fit in the space the disk was made by valeo
regards
Graeme
Hi Graeme
Thanks so much for your help, I will check this out. It is winter here now but I hope to have it on the road next summer. It is 10 below this morning. Brrrrrrrrrrrr.
Ron
If we get this clutch problem sorted out we may race it. I just finished a Cheetah build and we used it as the pace car at Black Hawk Raceway last summer. I had a Midwest Council racing license many years ago but I'm too old to race now. My son-in-law races a Swift DB1 and also instructs. Just can't get it out of my blood, I guess.
Ron
