O.K., time to finish up some hydraulics. Everything I have read says to use 1/4" hardlines with AN4 fittings for running clutch lines, this is because we are more interested in moving fluid volumes rather than transfering pressure. Why then are all of Tilton's master cylinder outlet ports AN3? If I use reducers down to AN3, won't I loose the volume transfer that I am striving for?
If someone could shed some light on the correct hardware to use, or a perhaps give a short lesson on fluid dynamics, I would appreciate it.
Brian
Brian
