Clutch relase fork GTD40 Renault UN 1 13 box
Anyone knows where to find one ?
Myne is broken on top.
Tx
FRed
Mike Pass
That looks like the Renault item. Try Frank Catt at Wealden Engineering tel 441323843839
Email. [email protected]
Or
Chris Cole. Tel. 44(0) 1952416051 No email
Maybe Renault breakers. The clutch fork may be common to the Renault 25 and 30 which will be more common.
If all else failed then weld it back together if you have the broken piece or make a piece to suit.
Fred, Update with a Renault Alpine 610 clutch fork, from any Ren. dealer...broken pins are a common fault on UN. boxes...I have 2 Alpines...I know.
Paul Hendrickx
hello if you're ducth speaking get in contact with Renault garage Benny Verhulst Hoogstraat 44 Bazel 9150 (Kruibeke ) 00 32 3 774 13 85 on off the references in Belgium for Renault Alpine spare parts.(has à web side also.... via Renault dealership
He has spare parts second hand new available, Renault 25 V6 is ok Espace Renault II V6 is ok old Renault Master is ok
check also out with Alpine Renault forum in France forum.alpinerenault.com
Had similar problem on my A310 , re-inforced clutch fork, welde-up on each side spacers with 8mm bore and placed 8mm steel stud for conection with slave cyilinder
Hi Paul
Many thanks for ctcs.
I found one in the meantime via Benny Raepers, another old Renault dealer with a lot of spares.
Bonne route en GT40
Paul Hendrickx
Hi Paul
Bonne route en GT40
The two Benny's are in Belgium the references for spares otherwise Andreas Simon in Germany nearby Bonn
merci et tot de volgende keer
