Hi, wondering how to make it wather proof around th door hinges. do i miss something from CAV, or do you make a bracket from where the spider ends down to the side skirt.
Hi, wondering how to make it wather proof around th door hinges. do i miss something from CAV, or do you make a bracket from where the spider ends down to the side skirt. View attachment 152833
On the southern gt design theers a piece of ali trim that goes between the the dash and chassis ,angled so you run the door seal all the way down will stick a pic up later today if it helps
Havard,
there is an aluminum plate that goes behind the dash and sandwiched to the chassis that continues the edge where the weatherstrip attaches to the spider. I'm sure you can have the factory send you one or you can make one up yourself. I don't have a picture of it but maybe someone on the forum does.
