At the Stoneleigh show yeaterday I came across a stand for Elite Racing Transmissions and had a fairly long chat with the owner.
He is aware of the RBT delays and also the need for mid engine transmissionsetc and had a coupl on show - mainly smaller stuff but also one he said was good for 600 torque
His web site is here
http://www.eliteracingtransmissions.com/?p=welcome
I also told him about this site and suggested he perhaps make himself known (Time will tell)
His boxes are all available with straight .or "quiet " gears and a lot are on a sequential system working off a single pull / push cable (Not without the clutch though although this is possible with intervention on the ECU to cut spark etc for the change under full throttle)
As they are the manufacturers that can make the input shafts and adaptors to suit whatever motoe / clutch you use.
