Flywheel fitting ZFQ bellhousing
Hi,
the flywheel on my Roush engine was too big to fit in the ZFQ Bellhousing.
The bellhousing is 361 mm inner-diameter.
Anyone can advise on a suitable flywheel?
thanks!
Hi Jonas I think there is some confusion over flywheels if you use the Zfq bell housing you will want a 157 teeth flywheel from a v8 our flywheel is smaller it is fitted to sgt cars using original size Zf bell housing you can use our flywheel but would require a different starter motor adaptor which I can probably make .
Regards mick.
