Factory Original Ford Wiring Harness, Regulator, Module and Ballast Resistor for a Transistorized Tach Drive Distributor, like part # XF 170429 (GT40) or a # XF 203105 for a 302 Boss. It came with several Transistorized XF Tach Drive Distributors I have listed in other ads. Believe this Wiring Harness to be of a GT40. Probably came of a late 1965 (used Dual Point Ignitions before 1965) or early 1966 MK1 or MK2. But also possibly of the later MK3, 1967 XE engine or Boss 302 car. Looking at the small Dzus Buttons on the Aluminum Cover, (where the Autolite Regulator is mounted) leads me to believe that this Harness and parts listed below came of the same type GT40, Boss 302 or other Factory Ford Race Car.
Here is a list of all the items included (as pictured):
1, Wiring Harness with paper tag, part # 9AF-12071A, 406379
2, Autolite Regulator 1-V C8AF 10316A says BFG on the aluminum cast housing
3, Ignition Relay ? 66AF 10A37?
4, Aluminum Cover with two Thumb Screw Dzus Buttons, 8 1/4" x 4"
5, Autolite Module C9AF-12A027-A, stamped 5HE
6, Ballast Resistor part # on wiring, near plug #C6TF 12A086-A, Reads on bracket:
FOMOCO, Welded Terminals, Disconnect at Plug, Back side reads "RBM" Made
in USA.
Price is $ 650.00, Located Orange, CA.
For further information send a PM or call (714) 287-5786
