I've got a front cover that looks like this. It has a boss that can hold a factory Ford distributorless pickup and uses a reverse rotation water pump.
Can this cover be used with the RF serpentine belt setup? If so, what water pump must be used? Late model 5.0L? If late model, which one as there are:
86-93 5.0L reverse rotation - medium length drive, used on lots of Mustangs etc.
94-95 5.0L reverse rotation - short drive, about 3.5" from back of pump to front. Also used on 91-93 5.0L Tbird/Cougar.
Explorer 5.0L - Do not know if it is the same as above or not.
I know this might cause some problems since car names are different in Australia. I figure the cover doesn't make such much difference, but the water pump will for the spacing etc.
Ron
