Hi guy,s, has anyone got details of the type of Lockheed servo,s fitted to the GTD. i.e. hyd. cylinder bore size and operating ratio 2.5 or 3/1 etc.
I have been having the usual brake sticking on problem, in my case with the rear brakes. I have just removed and cleaned the small piston that usually causes the problem so the next test run out will see if this has corrected the problem. If not I would like to replace the servo thus the request for details of same, without me having to strip it down. I run AP5000 fronts and Scorpio rears.
Regards Ron.
Regards Ron.
