Colin, I am not sure whether you got my email, so I'll post my reply here (it pretty much echoes Howard's advice) :
Hi Colin,
Thanks for the complementary remarks - totally undeserved ! Almost everything that I have learned about bodywork has come from an expert - I have a '71 Vette which is undergoing a total body-off rebuild & all the major external work is being done by a mate (Scott) who has been in the business of rebuilding / L/R converting mid-year Vettes for 20 years. Over that time, he has made all the mistakes & has figured out the best way to work with f/glass. Scott's job on the Vette is everything that can be seen & my job is the rest (fun places like underbody, interior, etc). As we have progressed in parallel, he has been teaching me all the tricks, so any apparent knowledge of the subject on my behalf has come from Scott !
For what its worth, here are some tips & stories on bodywork :
Power Tools :
The only power tool that I used was a simple Dremel, fitted with 60grit sanding drums - my first Dremel lasted about 2 years, so now I am on No2 - worth their weight in gold ! They are perfect for trimming back the overhanging rough edges of glass that you have added to door edges, etc. (Some of these were up to 1/4" thick - no fun by hand).
Another thing which would have been useful is an air-powered die grinder & a couple of fluted bits - one rounded & one straight. My air compressor didn't have the throughput to run one of these, so I had to make do with the Dremel. In hindsight, I should have spent a couple of hundred extra $ & bought a bigger compressor - that would have not only let me run the die grinder, but also a belt sander (handy for glass work & also on steel, etc).
Filling Faults, Etc :
Scott has learned that you never use filler (Bondo / bog) for anything larger than half a match-head in size. Larger volumes will ultimately shrink & settle at a different rate than the surrounding glass, & you end up with slight "sink-holes" which only become visible months after painting. The other reason he avoids filler is that it has a different hardness from that of f/glass, & this can make the flat-stick-sanding job tricky - the paper tends to bite a bit more out of the softer filler & you can end up with slight flat spots on convex curves.
Basically, Scott does any mods / fills which are larger than a pin-hole with glass & resin. The trick is to machine out the area, feathering the edges, then lay glass/resin in until it is proud of the surface. This approach takes a fair bit more effort with the sanding, but leaves a uniform surface.
Most of the faults on my bodywork involved little areas where there were voids between the blue gel-coat & the underlying f/glass, and spots where air had been trapped between the mold & the gel-coat. Make sure you suss out these with a small screw driver - its surprising how big a void was under some fairly small imperfections. I just dug out the gel-coat until I got back to the point where it was well bonded to the f/glass, ground the areas back with the Dremel, then glassed them up. There were very few of these in the bigger / flatter panel sections, but quite a lot in the more complex shapes & tight curves (inner door skins & intake ducts on the rear clip).
Scott's motto - "If in doubt, grind it out" !
General Glass Work :
I used chopped strand mat & wax-free polyester resin for all the bodywork. Some resins have wax in them & this percolates to the surface where it stays tacky for weeks. I am told this is designed to seal the surface if it is going to be left bare - but it is a bastard to sand (clogs the paper in seconds).
Scott's tips on good glass work are :
- Grind / sand the area, blow off dust
- Wipe down with acetone
- Build up another couple of layers beyond what you think is enough
- Consolidate resin/mat (with one of those grooved rollers), then consolidate again
Panel Gaps :
Panel gap work will depend on how good or bad things are now. I found that the gap between the vertical front edge of the door & the front clip was the driver - it needed to be nearly 1/4" to allow clearance as the doors are opened. This meant that "Lexus Gaps" of around 1/16" would have looked out of place elsewhere, so I just made them all about the same as those front door edges. I also found that the bigger gaps allowed for having to shut the doors somewhat "firmly" to overcome the resistance of the door rubbers - at one stage I had 1/8" gaps around the door tops, but found that the "give" in the rubber allowed the doors to hit the roof before relaxing back to the correct position. Gaps of around 1/4" solved this problem.
If you need to build out door edges, etc, I found that the best way was to square off the edge with the Dremel, run one layer of glass over the edge (with about 1/4" overhang on each side), let it set & provide a wide base for the next layers, then run up to 6 layers at a time over this. I first tried 4 layers in one hit & ended up with them all falling on the floor ! If you need to build up an edge, and also the adjacent flat panel surface, I found it best to do the edge first, machine off the overhang, & then lay glass on the panel surface so that it crosses the new edge build-up - this way you get some "cross bonding" that adds a lot of strength to the bonds.
Body Filing :
For rough body filing like shaping large areas of raw glass add-ons on panel faces, I started with 32grit on a flat stick or piece of exhaust pipe (for concave curves), then on to 80grit to get rid of the big scratch marks, then on to 120grit over the whole car. All of this needs to be done with long diagonal strokes around the curves - never to-&-fro in the one area. I found that because of the flexibility of f/glass, I had to have the rubber seals in place around the doors & rear clip, and latches tensioned down, to hold everything in its final place while doing the body filing across the panel gaps.
The big tip that I got from Scott was to use a long stick (10-12" x 3" wide) for the sanding. Apparently, it is impossible to avoid ripples if you use a shorter sanding block.
With all that done, it is probably best to run a fairly heavy coat of spray polyester filler over the whole car (see Paint System below). I made the mistake of running 4 light coats on & paid the price when we found hundreds of tiny pin-holes later on - I should have really wacked it on. The stuff is quite easy to sand back (nowhere near as bad as raw glass or gel-coat) & a 400grit dry finish is all you need before priming.
Another important tip I learned from Scott is to never use water in the sanding processes on raw glass, filler or primer - always use dry paper. The tiniest bit of water can stay in pin-holes for months, & will result in a humidity bubble in the final paint. The only downside to this is DUST - there will be bucket loads of it on you, the garage, the house, the neighbours, etc !! I figured that I put about $1,000 worth of filler over the car, & ended up with half of that floating around as dust !
My other big mistake was to wait for Scott to run a very light guide coat of GM Flat Black over the car - this is what showed up all the pin-holes, minor lumps & bumps, etc which are impossible to see when the car is in flat primer. If I had done that myself, I would have saved big bucks.
Paint System :
This is one of Scott's big hobby-horses - choose a complete system from one manufacturer & stay with it. We chose Spies Hecker (a DuPont company) as Scott had got his best results so far with this. The system was as follows :
- First coat was a thick spray polyester filler called Raderal
- Block back with 80grit, then 120grit, then 400grit
- Touch up any areas "sanded though" with thinned Raderal
- 4 x coats of Vario primer
- A light guide-coat of GM flat black
- Block back with 400grit
- Lightly grind out the pin-holes revealed by the sanding back of the guide-coat
- Fill with Vario filler (compatible with all other Spies Hecker products)
- Block back filled spots (400grit)
- Touch up areas over & around these with Vario Primer
- Final block back with 400grit
- Base Coat : Spies Hecker - 4 coats
- Clear Coat : 2-pack Spies Hecker - 4 coats
- Leave for a couple of months, then buff
Colin, I hope that this will be of some help.
Kind Regards,
Peter D.
